I have a stove without a removable ash drawer, can't imagine why anyone would design such a thing - but I am stuck since I never looked for that when I bought it. Anyway, I had been looking into ash vacuums to clean the stove with. Huh, $200+ for one of those. From anything that I have heard, even taking a shop vac to cold ashes represents a risk because of the abrasive nature of the ash from a pellet stove - never mind doing it with hot ashes. I am certainly reluctant to destroy a $100+ heavy duty shop vac to clean my stove! In trying to keep the stove as a main source of heat, I am reluctant to shut it down for several hours at a time in the middle of the winter just to clean hot ash.
Anyway, I devised this based on a unit that I saw on the internet. Handyman ability - beginner, tool availability - intermediate, cost - about $20 if you have some scrap wood and the proper sized hole saw/forstner bit/circle cutter.
I got a plastic 5 gallon bucket with cover from Home Depot for about $3. I cut some plywood and pine to fit the cover of the pail and the fittings (schedule 40 pvc). Fortunately, the pvc fittings were the exact outside diameter of my shop vac hose, so I didn't have to make any adjustment for the vac hose and fittings. I also got some filter paper for a standard shop vac and put it over one of the pvc fittings so the ash gets filtered before it gets to the shop vac.
Basically, this acts as a separator - no hot ash can get into the vacuum, larger particles get dropped in the separator, and I get filtered dust in the shop vac. I plan to add some cement to the bottom of the 5 gallon bucket to make it more stable on the floor and more resistant to melting. Obviously, you would need to empty it immediately anyway, being made of plastic. It seems to work quite well, so I am also looking for a good 5 gallon metal bucket that I can use instead of the plastic one and still get a good air seal.
It also seems it would work well as a pellet screener, if you vacuumed up a bag of pellets. You would end up with a five gallon pail of nicely filtered pellets at the end.
Here are some pics - if you want more details, let me know:
http://s256.photobucket.com/albums/hh173/darkstar2051/
