My apologies as I’m sure that this question has been asked before, but I could not find threads on that topic using the search tool.
We’ve replaced our old wood stove with a “constructed in place” masonry heater. I had a small fan blowing through from the ashpit to the damper at the top of the unit for a couple of weeks to dry out the mortar. I’m now connecting the stove pipe and have run into a problem.
The new stainless steel breech pipe into the chimney is 6” diameter. The ID of the damper assembly visible at the top of the heater is 5-7/8”. My understanding is that may have worked well with double-wall stove pipe, but the breech pipe enters the chimney at an angle, requiring an adjustable elbow. The distance to the nearest combustible surface is greater than 18”, so the solution that I chose was to use single-wall stove pipe (stainless steel rather than black). For this short connection I just need two adjustable 90 degree elbows and a short piece in between. The problem comes from trying to fit a 6” diameter stove pipe into a smaller diameter damper assembly. I’ve “over-crimped” the elbow visible in the photo and I can force it into the damper about one inch (where the green tape is), but the crimps are visible and gives the impression that the fitting is not in far enough. It doesn’t look like a very professional installation.
Is there a better solution to this? I don’t think that I’ll find a stainless steel adapter like this one that I mocked up in the photo below.
Thank you for any insight.
Chris
![StoveAdapter.png StoveAdapter.png](https://www.hearth.com/talk/data/attachments/264/264923-c293e4bf79ad3d63d68db4b98f60a952.jpg)
![StovePipeDillemma.png StovePipeDillemma.png](https://www.hearth.com/talk/data/attachments/264/264924-9ed57ad21d35dc310863745c84dc3ae6.jpg)
Chris
