Thanks Dix.. I don't have one. But will be ordering a few now that I know![]()
We've gone threw about 2 faces of pine so far. I know pine aint the best but it is what it is. Want to clean her good now before switching over to Hardwood as the really cold weather is coming in now.How much wood have you put through the stove so far?
Thanks.. I guess my being a welder will come in handyAlmost forgot.... be prepared, that baffle is going to be way, way heavier than you think. Ask me how I know this![]()
It looked pretty clean. If the pine was well seasoned I wouldn't expect much buildup from less than a cord.We've gone threw about 2 faces of pine so far. I know pine aint the best but it is what it is. Want to clean her good now before switching over to Hardwood as the really cold weather is coming in now.
Good to know! I was always planning on burning pine in the fall and then expecting to have to clean the chimney at least once during the winter. We only have 1000sqr to heat so we start a hot fire in the morning and let it burn out which is fine for the entire day and then another fire in the evening. Good or bad with regards to soot build up I'm not sure. But like I said I fully expected to be cleaning the pipe. This stove was installed in the summer and Im not familiar with the Baffle type.. but sure am learning tonight.. Thanks to everyone!Pine, is fine, trust me. Do a search, you'll be surprised. I burn it, never a problem. It just has to be seasoned, like all the others. I burn it spring & fall, sometimes mixing w/ hardwoods![]()
It was seasoned for the summer only.. but in the sun and its very light and seems very dry. I suspect any build up is from our practice of starting a fire and letting it die. We cant keep it going all day.. waste of wood and WAY to hot. Cleaning the chimney once or even twice a winter is not the end of the world.It looked pretty clean. If the pine was well seasoned I wouldn't expect much buildup from less than a cord.
I have the same brand but mine came in (5) 3ft sections, might be easier bending the 3ft'ers up through the stove then a single 5 ft lengthKenny.. is this the ones you have?
Well my trip to Lowes was a waste of time.. They are not as advertised. They are the same Yellow Fiberglass rods that I already own.I have the same brand but mine came in (5) 3ft sections, might be easier bending the 3ft'ers up through the stove then a single 5 ft length
