Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Hi, today I thought I would try running a 3" dryer vent brush through my pipe just to gauge how much ash was in it at this point. The bristles seemed too stiff to even push it into the pipe Am I using the right instument?
I have seen a brush designed especially for pellet vents. Do a google search. Not to expensive,
maybe 30 buck or so.
Let me know how you make out if you get one....its on my list!
I use a 10 ft flexible brush for the pipe too. Sometimes it gets a bit
stubborn going around the bends in the pipe, but will work if you twist it
around while forcing it through.
I've only been burning since October, just wanted to get a sense of how much ash can build up. I have sealed every rivet, joint, seam that can be seen. Don't want to have to take it apart until the end of the heating season. Simply want to run the brush through to the clean out tee to see how much is in the pipe so far.
if that stove is running right, you should only have to clean the flue once a season
i wouldent worry about it unless your getting really unusual ash build up in the stove, burning poor quality pellets, or installed too many elbows on the flue
pull off the cleanout tee and shine a flashlight up there. a simple visual inspection
At the end of the season, if you can get the brush all the way through
from the Tee to the outside, you should not need to take your pipes
apart at all. .....Guess it depends on the setup
