Anyone who owns an xtrordinair elite probably knows the mindbendingly stressful situation of the bypass control falling off of the damper.
Its near impossible to fix. Whoever designed the xtrordinair elite needs to go back to engineering school. I hope they read this thread so that they NEVER design a fireplace like this again.
You see, the damper is controlled with a pull rod. The pull rod is attached to the damper in a near-inaccessible spot which is held together with two ridiculously tiny 'prongs' which sit in two welded cups (the pictures below explain it all).
After the damper fell off the 500th time, I got so fed up with it that I screamed HORRIBLE ENGINEERING! THERE HAS TO BE A WAY TO FIX THIS!
Google 'Xtrordinair damper issue'. Its an actual problem. Actually, there are several threads on Hearth.com with people trying to fix this horrible mess.
One example from 2009 from @maverick06:
www.hearth.com
If you own a Xtrordinair and have constant damper issues with it getting stuck, the rod falling out, etc etc.. here is how you ACTUALLY FIX IT ONCE AND FOR ALL:
1. Look at picture from the manual to see how the damper is set up.
2. The damper is HEAVY! Do not let it fall on your arm.
3. Use a car jack (yes a car jack) and jack it up to hold the damper plate in place.
4. Remove the six bolts (theres a pic of the bolts)
4a. Put cushioning in the fireplace to prevent the damper from falling and cracking /breaking things. Remove the glass doors for safety.
5. use the car jack to lower the damper plate. The damper may fall out! WATCH OUT!
6. Use a drill bit to clean out the two cups on the plate. It will be filled with crud, ash, etc. (see pic)
7. Using a drill press, drill holes in the two prongs of the rod. I drilled a hole in a 2x4 to hold it in place while drilling (see pic)
8. Drill two holes through the cups. Just be sure you make the holes either high enough or low enough so that it lines up with the threaded rod once youre done.
9. Insert the prongs into the cups.
10. Using cotter pins, insert the cotter pin into each hole.
11. TAH DAH! The stupid prongs will NEVER fall out again! PROBLEM SOLVED! (Xtrordinair engineer SHAME ON YOU!)
12. Using the car jack, carefully and slowly, use the car jack and crank it back up so that it lines up with the threaded bolts.
13. loosely tighten THREE bolts to the threads (all on the same side)
14. remove the jack
15. Slide the plate with the now 'cotter pinned' prongs up and into position
16. use the jack to jack the whole thing back up
17. tighten all six bolts
18. slide the rod through the front of your fireplace, line up, and tighten the rod to the cotter pinned piece.
19. annnnnnnnnnnnnnnd.. YOURE DONE!
Your damper will NEVER fall out of place, get stuck, or unscrew again.
![11.jpg 11.jpg](https://www.hearth.com/talk/data/attachments/300/300955-3daa799a61d9427a2c4384a48d2d3b4a.jpg)
fixing the jammed damper on fireplace xtrordinair elite 33 (FPX 33) aka lopi declaration
Hi All, I have a fireplace xtrordinair elite 33 (FPX 33) which is the same stove as the Lopi Declaration, just a different faceplate. It’s a great stove, but like a lot of other people, the damper jams on it. The damper moves relatively freely when the stove is cold, and when it is hot. But at...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
14. remove the jack
![1.jpg 1.jpg](https://www.hearth.com/talk/data/attachments/300/300945-6af33195930883a261f3eca72427414e.jpg)
![2.jpg 2.jpg](https://www.hearth.com/talk/data/attachments/300/300946-ef25ef4e1c099931c67ecb0327467b83.jpg)
![3.jpg 3.jpg](https://www.hearth.com/talk/data/attachments/300/300947-bbd2ba46a1ca3cbc9c7268d40f313e5e.jpg)
![4.jpg 4.jpg](https://www.hearth.com/talk/data/attachments/300/300948-ead309aad18288c1af9245f6b2a4917e.jpg)
![5.jpg 5.jpg](https://www.hearth.com/talk/data/attachments/300/300949-df54d8ca24a8f29097a4ac7034a95815.jpg)
![6.jpg 6.jpg](https://www.hearth.com/talk/data/attachments/300/300950-df61ab912ec37c867683b5a93e33f968.jpg)
![7.jpg 7.jpg](https://www.hearth.com/talk/data/attachments/300/300951-5966671f525d47b28ad56ae255688a5c.jpg)
![8.jpg 8.jpg](https://www.hearth.com/talk/data/attachments/300/300952-765c32cf4f18045171e71ef710588a47.jpg)
![9.jpg 9.jpg](https://www.hearth.com/talk/data/attachments/300/300953-e91c5348bf768534edb1797ff57262e6.jpg)
![10.jpg 10.jpg](https://www.hearth.com/talk/data/attachments/300/300954-13d2b542b3ad0c59ef91344a6075c3ce.jpg)
