E
elkimmeg
Guest
I saw this hearth pad being built the other day and thought I would pass the info on..
The guy bought metal high hats (metal high hats and like 1.5” metal straps used on concrete walls to attach sheetrock I think Home Cheapo sells them.) He first laid down common fiberglass insulation but to leave an air space between the fiber glass and the metal high hats he cut a bunch of ¼” copper pipe he placed under the metal straps there allow spacing that the insulation is not completely crushed and reduce metal contact combustibles the copper pipes were laid on the side and cut just a bit longer than the width of the metal high hats. The insulation he used was HVAC duct wrap foil faced R-5.2. He centered the high hats 12” on center and place additional cross ones where the stove legs would be. His top was to be Durarock , faced with tile. He built it one inch larger for clearance distances and planned to use leftover mahogany 5/4 decking, that he would router a molded looking edge to ..
You can trim the edge with wood providing it is outside the clearance to combustibles distance. I liked this guy plan he achieved a high r value foil faced insulation has a reflective value and I passed the setup. He told me his total cost was less than $100 the tile being the most expensive item. What I liked best was his copper spaces creating separation distance and allowing an air space gap. The total thickness was less than 2.5”
R- value 5.2
R- value 5.2
