Island-Doc said:
So, anything over 2" is burnable as fuel, anything 1" to 2" is kindling and anything under 1" is for the 'burn with the yard waste' pile?
Stoves are a VC defiant and a VC intrepid, both NC and both on insulated SS flue pipes running up inside interior masonry chimneys. I also have a VC 'model 46 Fireplace Insert' and a VC Winterwarm (small) Catalytic insert (again both on SS insulated flues in interior masonry chimneys).
That's about right, within guestimated limits - I may go a bit smaller on the kindling sizes as long as it's easy, but don't go nuts about it. By the same token it is best to avoid loading your wood pile with too many small diameter rounds - either mix them in well with the other larger splits, or keep them separate and just bring in a few at a time. The small stuff will burn fast and relatively hot, so you don't want to stuff the stove with just the little stuff, but it's good for balance and getting the "all-nighter" logs going.
Also it depends somewhat on your burning habbits. If you are mostly a 24/7 burner who almost never lets the stove die down or go out, you will need less kindling and small stuff. If you are an "intermittent burner" who is frequently needing to re-light the stove you will need more small stuff. I have a 5 gallon bucket I used for kindling - during the winter I was maybe filling it once or twice a month, now that it's warmed up I'm filling it a couple times a week, all because I don't keep the stove going as much.
Goose - how'd you make out with the flooding? Any problems for you? Heard it was pretty bad in the Lowell area.
Gooserider
