bluefrier said:
It varies (of course) how often you need to sweep, a new burner should check the chimney once a month
to guage soot/creosote build up. If you have alot of buildup in 2 1/2 months your wood or burning habits
are the biggest factors. Make sure you burn properly seasoned wood, get a moisture meter if you have to and
get your wood below 20%. Burn hotter fires to keep creosote at bay, get a stove top thermometer if you don't
have one and try to keep the stove above 400*. Once you get the hang of it you should only have to clean
the chimney once per season.
Thanks, I do think we haven't been burning the most seasoned wood all of the time. AND we have been using it as our primary heat source thus far.
Is there anything you can add to a fire (like you can to a standard fireplace) to keep creosote at bay)?
Yes, we do plan on going up there this weekend and giving it a thorough cleaning.
