How much creosote on BK princess is too much?
leddyleds
3
Talkeetna AK
Howdy all, we’ve been burning our new BK Princess about 3 months now and we sweep our 24’ straight, 6” chimney every month. We burn white spruce and birch that’s been seasoning 6+ months (the birch up to 2yrs seasoned). When I sweep chimney I get maybe 1-2 cups of creosote, however the firebox is just caked in the stuff. I remove as much as I can but a lot of it is behind panels that I can’t remove (see photos). I take a razor to the glass door monthly and usually can get tons off the door too.
Question is how much buildup in the firebox is too much? I assume this is an outcome of using a catalytic converter, but am I doing something wrong to have this much buildup? Wood still to moist? Sorry I don’t have a moisture meter, but wood is stored in a dry shed with good airflow and I do drop and split wood at least 1yr before I’ll start burning it.
Thanks in advance to any advice!
  • [Hearth.com] How much creosote on BK princess is too much?
This is what happens when you burn low all the time.
Burn high for an hour or two every now and then. It'll burn stuff off.
I do have a 1.25" dua brush on a long flexible metal wire that I use to behind the shields.
I'll do a hot burn every other week to help bake off the inside of the stove box, it may not get it all at the first go, but if you do a few maintenance hot burn cycles it will clean things up a bit.
Don’t be surprised if it takes much more than a couple of hours to dry out those deposits so that they flake off. Softwoods burned slowly can really put some thick gooey junk in the firebox.
Reactions: all night moe
