How much, how often do you buy a jug of oil... Am I suppose to be going through a whole bunch of oil while cutting and also seeing splatters only at times in front as I am cutting? Thanks for your input....
i can't give a precise amount i use because i use 10w-30 out of a gallon jug that i also use for topping off a vehicle i have, but the resevoir is probably half empty after an hour of on/off use, but maybe less used than that, because i tend to keep it topped off. i'm sure i would use less with straight 40 weight, or dedicated bar oil, but i get the 10w30 anyway, so it's what i use.How much, how often do you buy a jug of oil... Am I suppose to be going through a whole bunch of oil while cutting and also seeing splatters only at times in front as I am cutting? Thanks for your input....
+1You shouldn't see it spatter out unless you are sitting there reving the saw. While cutting, the oil goes into the wood.
I use a lot as mine leaks while sitting. Although I found if I relieve the pressure by removing the cap when done it leaks a lot less
how long are your splits? if they're 2' you have about 240 cu. ft. of wood, or a little less than two cords. if they are 16" than you have about 156 cu. ft. a cord is 128cu. ft. just multiply width x height x depth.Also jus a question, a 20ft wide face cord 6 ft high is equal to how many cords? Thank you
So 1 3/4 cords is a good guesstimate?how long are your splits? if they're 2' you have about 240 cu. ft. of wood, or a little less than two cords. if they are 16" than you have about 156 cu. ft. a cord is 128cu. ft. just multiply width x height x depth.
Do you run canola oil in winter and summer ?I use a good bit of oil too, but always run canola oil through my saws.
taking the average of 14-20" (17") puts you right at 168 cubic feet or almost exactly 1 1/3 cords. if you need to find how much you have, just pull up your computer calculator and plug the numbers in. the easy way to use 17" is 17/12 = 1.4. so 20 x 6 x 1.4 = 168So 1 3/4 cords is a good guesstimate?
YesDo you run canola oil in winter and summer ?
Thanks..taking the average of 14-20" (17") puts you right at 168 cubic feet or almost exactly 1 1/3 cords. if you need to find how much you have, just pull up your computer calculator and plug the numbers in. the easy way to use 17" is 17/12 = 1.4. so 20 x 6 x 1.4 = 168
I run Wesson Canola Oil, 5 quarts or 1.25 gallons per jug. I just bought two but gave one to our neighbor so she could try it. I never kept track on how much I use but will starting this weekend, ending this fall or winter.How much, how often do you buy a jug of oil... Am I suppose to be going through a whole bunch of oil while cutting and also seeing splatters only at times in front as I am cutting? Thanks for your input....
