How many,
It depends on the species of wood, the area being heated and outdoor temps. The harder the stove is pushed the more fuel is consumed. 3 times a day is average for us. But if it gets below 20F more like 6 hrs. In mild weather it could be once every 10-12 hrs.
Reactions: davidmsem
I'd say every 7-10 hours right now. Wood isn't my primary heat source.
And according to my wife, I'd "better not put anymore wood in that stove tonight" because she'll "sleep on the deck in the snow" as it is getting a wee bit toasty inside. lol. So no reload tonight before bed.
ANdrew
Ideally, my goal is 2. If it is dipping colder, say <20, then I may do a 1/2 load to bridge the end of my day load and my re-load for overnight.
Hovering in the 25-35f range I average 3 full loads a day 3/4 splits per a load. May be a half load in there somewhere or may not be, depends on wood , wind, sun, and my personal attitude on any given day.
As it gets colder I load more often and earlier this consuming more wood, but haven't been there yet this year so I'm not sure what that consumption is.
Reactions: Smalltownwoodburner
ANdrew
My living room is holding around 88 at the moment. Pretty mild night. Load the stove full 2 a day. Partial load 2 a day.
At 88 my wife would be out on the deck. We like our bedroom around 66-70.
GOod grief. At 88 I'd die. My body wasn't meant for long term super high heat. Otherwise I'd have a radiator built into my forehead. :)
Now a nice cozy 76-78. Perhaps. 88: all promises of marriage are off. lol.
Andrew
I was a mistake on my part. I have a window open at the moment. If it's 68 I'm happy. Sweating at the moment.
This has been the mildest winter here in South Carolina that I can remember.
X2 for me in upper 20s weather with some solar gain. Right now with the cold snap we are having 3 times with a small load from just before dinner till the night load. (Helps burn down the excessive coal/ash pile as well!)
I love the heat distribution in my house. 90 in the den by the stove, other parts of the house around 80 and the bedrooms 70.
Works perfect for me.
Reactions: Swedishchef
I can't compete with the temps you folks like. When I have both inserts running and its gets to the mid 70's, I can't take it. Like it about 70.
I can't comment.
[Hearth.com] How many,
The absolute hottest I can take it is when my thermostat says 77, and honestly it's too hot. That puts living room/kitchen area at probably 82-84, and bedrooms 70-72. Too hot for my liking.
72 on the thermostat is nice, with stove-area of house still nice and warm and bedrooms a little cooler.
Sounds overheated. Those temps are not healthy in the winter. In the summer at what temp do you turn on the AC, 78F? Feed the stove less wood and let it go out if necessary.
Who are you asking?
The 88F hothouse.
Reactions: AnalogKid
The 88F hothouse.
Lol, I agree. I couldn't imagine.
Actually a little ironic that this conversation is taking place.... Just last night I woke up around 2am and was way too hot so I got up and closed our bedroom door. Well, my wife got up later to go out to the kitchen.....and, WHAM!! I felt terrible.
I have gotten into some really good seasoned locust and with the temps not terribly cold currently in CT, it doesn't take much to get the house too warm.
We've just gone through a few weeks of that stuff. If it's over 45F outside I let the heat pump handle it. Dropping below 40F now and with a stiff north wind. We have been burning steady, but the living room is only 74F and the rest of the house around 70-72F. Perfect. I might switch to hardwood for the next couple days, love the way it burns.
I had to go check the thermostat.....72. I'm in the room with the stove and it's toasty. Perfect in all areas.
It's cooling down now. For the next week it looks like low-mid 30s day/low-mid 20 overnight.
I average 2 full loads per day per stove, but often break the second full load into two slightly smaller reloads at 6pm and 10pm. Big load in the morning for 12 hours, a small load in the evening for 4 hours, and a medium load at night for 8 hours. The stoves are run with air control shut tight for the two longer loads, but often hotter for that 4 hour load in the evening.
