Hi,
I live in Portland Oregon and recently installed a new pellet stove. I was wondering if anyone in the Portland area can provide me with their usage so I have some idea how many tons I should stock up on? Portland's weather is relatively mild, so I don't expect to need the stove 24/7 all fall/winter, but even if I do I have no idea whether a low setting will be sufficient or others experience indicates I will need to crank the stove up to stay warm.
My stoves specs are: low = 1.7lb's/hr, 14,000 BTU/hr,
med = 2.6lb's/hr, 22,000 BTU/hr,
high = 4.5lb's/hr, 38,000 BTU/hr,
I will be heating approx. 1500 square feet and I hope to use the stove as my only heat source.
Also I have purchase Blazer pellets from HomeDepot ($3.99 per bag). Any one have any experience with these pellets? Good/bad? Little ash/lots of ash? Low BTU's/high BTU's?
A neighbor recommended Golden Fire pellets, which Parr lumber current has, but they are $4.50 per bag (or $215 per ton). So they cost significantly more then the Blazer pellets at HomeDepot.
Thanks in advance for any help you can provide.
Jim
Jim
