How many seasons can I expect to get outa my door gasket before it's time to replace it? How long did YOU go, before doing so?
-Soupy1957
-Soupy1957
BrotherBart said:3.216 seasons. If you start using the stove in September of the first season you will need to change the gasket on November the 12th of the fourth season.
soupy1957 said:Based on "Backwoods Savage's" response, I'm wondering "why" yours, (daveswoodhauler) only lasted "2 burning seasons?"
-Soupy1957
perplexed said:BrotherBart said:3.216 seasons. If you start using the stove in September of the first season you will need to change the gasket on November the 12th of the fourth season.
You seem well versed in mathematical computations so I am wondering if you can help me out so I make sure I do not go past the optimal gasket changing time here. My math. skills are a bit rusty and I simply do not understand what the numbers mean that come after the period that follows the 3. Is that like the starting of a new sentence or something so one can expect to have a gasket last 216 seasons if one should live that long??? or do those numbers represent a secret code only seasoned wood burners are privy to?
Then one has to wonder what the 3 means....
What happens if you start using the stove in Sept. of your first year and in October in the second year and you skip a season due to global warming and then on the fourth season you start up in June? ..
.... :gulp:
BrotherBart said:perplexed said:BrotherBart said:3.216 seasons. If you start using the stove in September of the first season you will need to change the gasket on November the 12th of the fourth season.
.... :gulp:
With rusty math skills it is safer to just go ahead and change it every year. :smirk: Even if you don't use the stove.
soupy1957 said:How many seasons can I expect to get outa my door gasket before it's time to replace it? How long did YOU go, before doing so?
-Soupy1957
soupy1957 said:North of 60: It's EXACTLY like that! It's amazing how much you can learn about a person's driving habits, (driving a wood stove OR a car), that way!
-Soupy1957
north of 60 said:By the way, I am on my original door gasket and still does good. Also lots of door adjustment left. On my Napoleon I changed it mid season 1st year and sold it in the second year after changing the upper baffle boards to brick the second time. Hope this helps.
Cheers
BrotherBart said:north of 60 said:By the way, I am on my original door gasket and still does good. Also lots of door adjustment left. On my Napoleon I changed it mid season 1st year and sold it in the second year after changing the upper baffle boards to brick the second time. Hope this helps.
Cheers
Can't help it if you don't know how to burn a non-cat right Alice.
north of 60 said:Trying to explain the variables. You know as well as I do Trixy that its hard to compare.
BrotherBart said:north of 60 said:Trying to explain the variables. You know as well as I do Trixy that its hard to compare.
You have every episode on DVD don't ya? Admit it.
First I had heard that you sold the Nap. Thought is was heating the garage.
