IPLUMB said:
I have a Hearthstone morgan insert with a full reline, Interior chimney so I didn't insulate my flex liner, My question is how hot do you guys think it gets inside my masonery chimney between my top plate and my damper block off plate? I always worry about it,This is my third season with this stove. Thanks always thinking Aaron....
P.S. I've watched this forum for years but this is my 1st post :wow:
In normal operation I would expect the flue tile temperature to be from as low as 150 degrees to as high as 300 degrees. The reason chimneys are tested to such high temperatures is only because of short and hot chimney fires, which can occur when tars on the inside of the pipe (that have built up over time) ignite. Luckily for you , a number of things are in your favor....
1. A clean burning newer stove.
2. Stove has controlled air, so even if buildup in pipe ignites, it is limited in terms of air - and therefore temperature
3. You have a liner within a liner within a chimney.
In real world situations, I have never run into a relined chimney/modern stove combination where the liner has gotten so hot that it presented a danger to the wood framing which is typically 6" or more from the flue liner interior. In other words, the situations of your type that would worry me most would be:
1. Older creosote hog wood stoves (pre-EPA).
2. Chimneys with no flue liner and brick/mortar which is falling apart.
In other words, short and sweet - if your original chimney was 1/2 decent, you are probably OK....given the basics above, I would feel comfortable with that installation. Consider that up until recently, it was OK to install that stove with no liner at all - just a short pipe through the damper. The liner increases the safety factor by a LARGE amount.
If, on the other hand, you live in a restored 1820 Cape Cod with original chimney....well, I'd want that liner to be either insulated or have some spacers so it was suspended in the center of the chimney flue....or BOTH.
