Well the day is near. I unloaded the EKO 40 on Saturday and managed to get it in the basement. My two 500 gallon propane tanks will be delivered this week.
I have been planning on using black pipe (1-1/4") for all of my plumping except for my heat zone loop. I will be using 1" Pex AL to pipe the HX inside my forced air furnace.
If you had to plumb up (2) tanks to the boiler with all of the necessary valves, shutoffs, etc would you choose black or copper? Obviously black is a lot cheaper than copper currently. Black pipe is easily available pre-threaded. One downside to black pipe I am thinking about is how well things fit together at the end. I may end up with one "custom" piece of pipe to get it to all fit together. I guess the other side is how much longer it will take to run black pipe (as far as tightening, working with the putty, etc).
Any thoughts?? Since I should end up with 40' or less of pipe, not including the Pex, I could potentially justify copper if it were really that much easier....any thoughts would be greatly appreciated...
