I've seen it mentioned several times.... and I've even been told that I should do it months ago....
But I still haven't sealed my stove pipe. My setup involves Durablack singlewall stove pipe that slips together with the top piece being a slip connector for proper height adjustment. I'm having no issues right now, and I have taken some of the advice and used three screws at the joints... but no sealing cement (furnace cement?)
My stove pipe involves two 45 degree elbows to offset the pipe to the chimney and I currently enjoy being able to clean my chimney monthly by unscrewing the stove pipe from the flue collar and slip the whole pipe assembly off (since the top part is a slip connector it slides up, rotates and slides down to get the pipe out) this leaves me with a straight shot to my chimney from indoors and makes easy work of frequent cleaning with a chimney brush and garbage back to catch the gunk. Because this system has worked so well for me and since there are no problems to speak of (peak carbon monoxide detection of 17ppm according to kidde) I've never been able to bring myself to shut the stove down long enough to seal the joints
I have some furnace cement coming so I can seal it if I must during my next cleaning.... but is it really necessary? My setup is working so well and I don't want to screw it up by taking apart my pipes.... and since its a slip connector and I will frequently be removing the pipe from the stove for cleaning, two of the joints won't be sealed anyway. (top and flue collar) I figure the creosote I'm creating with my marginal wood this first year is doing the sealing for me.
Thanks in advance.
Thanks in advance.
