I have access to a lot of standing trees that are dead and have no bark left on them. They range from 5" to 18" or so in diameter. They are mostly Elm, Walnut, and Oak. How soon would you burn them after they are cut and split?
Trail_Time said:As others have said be careful of the limbs breaking off above.
valleyflyfisher said:When falling snags, always keep an eye on the top, especially while wedging, I have been witness to snags that crumble as soon as the bar hits the base while making the first cut. Its also a good practice to make your undercut deeper as it will let the tree fall further before bottoming out on the base of your undercut, meaning less chance for the top to come down, which happens at times when the tree is rotten and the undercut shallow.
Always a good idea to have a easy escape route too, don't need to be tripping up on a root or ? while trying to get out of harms way. A good practice to get into when wedging, is to watch the top of the tree on every stroke of the axe on the wedge, a baseball bat sized limb coming down from 70' up, can and will, kill you.
....make your undercut deeper, from top to bottom, not front to back. Although, it is a good idea to make your undercut a little deeper (front to back) never go further than half way.AC-D14 said:I have access to a lot of standing trees that are dead and have no bark left on them. They range from 5" to 18" or so in diameter. They are mostly Elm, Walnut, and Oak. How soon would you burn them after they are cut and split?
