I know this idea may immediately get shot down, but I'm trying to see if it could work. I own a Green Mountain 60 with a 18' double insulated chimney that rises straight up from the stove, no turns.
I know this stove can have an outside air accessory. My dealer didn't seem to think I needed it, when I asked there wasn't much thought. (Some may recognize my username with a recent issue I was having. That has been fixed. I was burning wet wood and my chimney cap spark arrestor was completely clogged after only 2 months of use and I didn't realize it. I have a new cap due to possible wind issues, I am intentionally burning hotter with drier wood, and my issues have gone away. Anyhow this isn't why I'm considering an outside air intake.)
Our basement is freezing. Previous owners installed baseboard heating because: 1) the space finished but rarely used, same with us; 2) the registers for forced air are at the ceiling and there isn't adequate return air to cycle the cold air.
The stairwell to the basement is wide open with no doors. In that way our basement acts like a cold trap as all the cold air falls down the stairwell. At the opposite end of the stairwell is our stove.
I was thinking about sending a pipe down under the stove and attaching it to the air intake on the stove (possibly with a flap to bypass the pipe if the length would cause issues). The pipe would extend all the way to the the floor of the basement pulling air from there. In this manner I would hope to warm the cold basement air which would allow warmer air to travel down the stairway to replace what the stove pulls in. This could also create a cycling of moving air.
What would be really cool is if instead of feeding the air intake on the stove I were to simply attach the pipe to a heat exchanger metal box on the side of the stove. This way as the stove slowly heats it would warm the air at the top of the pipe creating a thermosiphon.
People have posted something similar on youtube, like this one. But my idea wouldn't change the chimney at all. Two immediate thoughts are 1) maybe it needs higher EGT to activate the needed thermosiphon air flow, and 2) is the length of mine extending into the basement too much for a thermosiphon.
I'm looked at "pass-through registers" but they only suck up the warm air at the ceiling and so aren't really effective. I've also considered an active system which may be the only option if I wanted to do this. Of course maybe it's simply not worth it.
Has anyone seen such a thing?
