So I have watched videos on how a catalyst burns using the propane gas demo. I get that it burns a fuel and I am guessing its preferred fuels are the gases of incomplete combustion from the fire box. Once the catalyst is active and the damper is closed and directing everything through the catalyst chamber, how does changing air flow to the stove affect the catalyst burn and temperature? I have read here that opening the air intake more will help bring down catalyst temp. I have also read the opposite. Does increasing air cause the wood in the fire box to burn more completely, thus cutting down on the incomplete combustion products or would the increased air increase the burn rate of the wood causing more heat and more fuel for the catalyst. It seems like people are working hard to chase the catalyst temperature up and down to find the sweet spot.
(I mentioned over in the VC area that I would love to have a pinned post on best practices for running a catalyst stove. It is pretty difficult to piece together from literally hundreds of posts on the topic and the VC manual is pretty bare bones).
