For those of you that have 'em, how do you set your adjustable blowers? Do you find there's a more efficient setting (an art or variance to it) or do you just have it blowing at the maximum speed at which it'll spit out warm air?
HotCoals said:I like that the blower will shut off if the stove gets to cold to produce decent heat on my new BK.
I don't know when they started doing that.boonefrog said:HotCoals said:I like that the blower will shut off if the stove gets to cold to produce decent heat on my new BK.
Is the thermostat-based shutoff a newer feature? I'm still trying to identify my wood stove and it has that "cutoff" mode. It would be a good starting place to know what decade it's from...
Roxburyeric said:High all the time. Why let the heat go to waste.
HotCoals said:Signature
24 year old BK Classic ,New BK Cat coming soon!
par0thead151 said:what i would like is to find out how to plumb my own blower so i can have it move even more air when the thing is really cooking.
is there any reason i should not double the airflow, assuming the temps of the stove are high.
RenovationGeorge said:par0thead151 said:what i would like is to find out how to plumb my own blower so i can have it move even more air when the thing is really cooking.
Hey PH,
If my calculations are correct ;-), the more airflow on the stove, the more heat you suck out, the faster you have to burn to keep the fire going, and the more often you have to reload. Correct?
Those may or may not be considerations for you.
Has anyone ever had so much airflow that the stove couldn't keep up, and went out?
spencer186 said:I'm by no means an expert, but I would believe cranking the blower is only going to cool your stove temps. I don't think it really changes the rate of combustion or could ever put a fire out. I could be wrong though.
WOODplay said:I have a LOPI Endeaver.
I run mine Med/Low all the time. If not it gets too hot!
If I don't run it at all it can almost get to the point of over heating.
