How do you adjust hinges on a VC Encore?
Diabel
3,862
Ottawa, ON
I noticed that I can pull through a dollar bill on the sides of the doors, between top & bottom door hinge. I loosen the two screws & the door becomes loose, but as I tighten it back the door goes back to the same position!!!
Any tricks?
Thanks
Diabel, maybe a stupid question but have you adjusted the door latch to pull doors shut tighter
I also remember a thread on here about a vc rep hitting door with a rubber mallet to get a better seal and it worked.
Yeah, I did adjust the door latch, thanks!
It is weird, I replaced the door gaskets recently & I tested both sides (perfect seal) & just by accident I did the test today & I can pull the bill on both sides ....only between the hinges. I am becoming a bit impatient with this stove...
