G'day All,
I've felled a few trees recently including a big one, leaving me with some stumps:
Medium stumps along fence - I left some height in case a machine can push them over easily
My big stump is about 75cm / 30 inch diameter cut fairly close to ground
I've done some interweb searching and people dig small ones out by hand, use large excavators or bulldozers (which I don't have) for big ones, or blow them up (tempting but it's close to my house ~15m away). I've also heard about stump grinders but never used one, always keen to give anything a go once. I heard they charge a daily rate and also teeth wear so the goal is to only let it grind wood.
I reckon it would take many hours to dig around the roots and cut through them or prepare for a stump grinder, I'd like to save myself the labour time if possible, even if an easier method takes months. I heard from a mate you can keep poisoning the stump with something and eventually burn it out, but he wasn't sure what you used or how long it would take before you could burn it.
Any suggestions? The goal is to level my grassed backyard for the kids to play in. I could probably cut the fence stumps close to ground then cover with dirt and grass but the big stump is quite high compared to the rest of the yard. Thanks in advance!
![How do I remove stumps easily? How do I remove stumps easily?](/talk/proxy.php?image=http%3A%2F%2Fsoede.net%2Fsoede%2Fimages%2Fstories%2F20131021%2520backyard_stumps_along_fence.jpg&hash=ccd098b5dc55beb30af49528832dcfa4)
![How do I remove stumps easily? How do I remove stumps easily?](/talk/proxy.php?image=http%3A%2F%2Fsoede.net%2Fsoede%2Fimages%2Fstories%2F20131021%2520backyard_big_stump.jpg&hash=1a4f5c0968c8007c2239f37851cc666c)
