The picture shows a 25 year old PVC line that goes to a refrigerator's water dispenser. It's cracked where the ferrule inserts, so its leaking. The view is from the bottom rear of the fridge and I can just barely move 3" of line outside the fridge for access. Not much slack if I make a mistake and cut it too short.
I want to cut out the cracked section (1/2" or so) but don't know how to get a proper clean and square cut. I'm afraid to use the squeeze type razor cutters on such old PVC since it will probably crush it. I know the right answer is to replace the entire line but its internal to the fridge and I don't want to get into that. I was considering a hacksaw blade but not sure if that will be a clean/square enough cut.
My plumbing skills are not great, I'm lucky if a brand new faucet doesn't drip when I close it.
![How do I properly cut very old flexible PVC so it won't leak? How do I properly cut very old flexible PVC so it won't leak?](https://www.hearth.com/talk/data/attachments/296/296111-73d9a038b8dd48db6f24f9946dbd4266.jpg)
