My settings depend on the pellet. MWP Soft require a higher feed rate of 4-5 whereas North Country, Vermonts or Spruce Point (anything with consistent small pellets) use a lower feed rate of about 2-3 max. Most others (general big box stuff) fall in the 3-4 range.
I never understand this either. The only time I turn my feed rate dial is when turn it to test when I clean the stove. Otherwise it is ALWAYS on 4.5.I fail to understand why you need to adjust your feed rate. Leave it alone and the stove with make all the adjustments it needs all by itself.
My P68 is in the basement (I bought the house with it) and the sensor runs up to the living room. So I usually set it to room temp at 70 with feed rate of 4.
We range from -2 to mid 20's in western ma during the winter. I burn about 2 bags a day.
