How close to outside corner can I run pipe
Vallka
6
squamish
Hello All
We just got a new Pellet Stove, I want to place it in the corner of the house, how close to the outside corner can I run the vent pipe?
From what I have found on the web I need the Venting Termination to be 12" from the corner, but what about the pipe, dose it need to be back 12" as well?
We do live in Western Canada so not sure if this makes a differance.
Thanks for your time
Troy
I know where it should vent, I can run pipe inside the house and vent it outside 12" away from the corner, but nowwhere can I find if I can run the pipe on the outside 12" from the corner. All that is ever listed is the vent should be.
Well down here the specs/measurements are "to the center of outlet(thimble) and/or centerline of pipe from outside corner".I would imagine the same up there except maybe for distances.Also pay attention to the inside of the house corner dimensions,usually different.
