Hello fellow wood burners,
I had my Blaze King Sirrocco 20.2 installed this fall and it works great, but it is hard to get the heat to spill into the kitchen/dining area (see attached diagram/layout) or into the den. It is noticably cooler in there, not terribly comfortable. Of course, the bedrooms are closer to the woodstove so that is logical, that the heat spills into them pretty good. There are no more floors besides the basement and the main floor which is shown on the diagram.
The air intake for the gas furnace (which is in the basement, which is 2/3 crawl space) is on the main floor next to the woodstove, shown in the diagram. I have a furnace fan that I turned on full time but it seems to just pump in cool air through the heating ducts (also shown in the diagram), and doesn't draw enough warm air from the stove to redistribute throughout the house. All the ducts seem to blow cooler air than room temperature. So, I turned off the furnace fan. I have a ceiling fan in about the middle of the living room turned on reverse so it is blowing the warm air upwards, across the ceiling and down the walls (I can feel the breeze off it when I sit on my couch).
I've also put some fans on the floor in the kitchen/dining room and closed the door to the den (where my girlfriend sleeps when she is over) She is coming over tonight and I'm planning on supplying her with a small electric plug in heater. I've also closed the door to bedroom #2 (see pic) so the air goes more into the dining area. Bedroom #2 is used as an office where I do some self-employment work, and use the computer often so I need to keep it open.
I would like more heat flow throughout the house. There are many variables right now, all of which I've fiddled with and had some success but not enough solutions found yet:
- The furnace fan which can be turned on or off.
- The ceiling fan in the living room.
- Floor fans in the kitchen and/or in the den.
- Doors to rooms which can be opened, closed, or left partially open.
- And, the worst: a winter vest and/or a hat taken on and off depending on where I am in the house (please, no!)
And, there are variables which are not utilized at this time (and I am probably not aware of all of them, nor do I know if these are valid but I'll wing it and write what I think I MIGHT be able to do):
- Installing a more powerful fan in the furnace to suck more warm air next to the woodstove into the ducting and through the heat vents throughout the house.
- Installing a fan that sits just inside the furnace intake vent next to the woodstove to suck air down so the furnace fan can work better at redistributing the heat.
- A larger ceiling fan in the livingroom ( it's a small room, so the 36" "ceiling hugger" fan with 6 blades seems to do fine in that small space without cluttering the ceiling and room too much).
- doing a small renovation to enlarge the doorway between the kitchen and living room (bah humbug; I got enough to do!)
- installing, or moving the existing thermostat to the gas furnace so it kicks on more often (really do not want this -- the whole point of the wood stove was to stop burning gas) It currently sits five feet from the wood stove and I just want gas heat when I am out of town.
So far, the floor fans in the kitchen blowing the colder air gently towards the stove seemed to help the most so far (as other threads in this forum have shown me works for others); before I did this last night, a friend was over and we remarked at how much colder it was in the kitchen than the living room and how there seemed to be a "wall" of cold that prevented the warm air from getting through the door and entering the kitchen. However, I'm still wanting more warm air into that kitchen/dining room and den than the floor fans seem to provide (although they're not very powerful - one is an 8" fan, the other a box fan). Besides, it is still pretty mild weather and I'm worried that when temperatures drop it will be mostly uncomfortable in almost half my home! And, I really don't want to augment my woodstove with an electric heater or a heat pump in the colder part of the house if I don't have to. This all seems to be a convection/airflow issue.
I know I should really better insulate my 80 year old home. Although I have double glazed modern windows, the walls are 2x4 studs and the insulation is not all that great. But, at this time, I can't really afford to do this.
Please advise and let me know if there are some variables or solutions I'm not exploring. Thanks, y'all!
~BC Josh
![How can I redistribute wood heat better in my house? How can I redistribute wood heat better in my house?](https://www.hearth.com/talk/data/attachments/318/318005-acbc0928a530b9c879479b4c301437b6.jpg)
~BC Josh
