How can I recover waste heat from hot air exaust
Danny D
10
Louisville Ky
I have a 250,000 BTU gas forge in my shop that produces a LOT of waste exhaust heat. I have a hood over the forge ducted into a 12" pipe with a 1/2 HP in-line blower to pull the exhaust out of the shop. The temp in the pipe runs about 350 to 400 degrees F. Not sure on the CFM but it will blow your hat off. I want to use the exhaust to heat water in an 800 gallon tank for hot water heat. I thought of putting a truck radiator in the pipe. How could I best transfer the heat from the air in the pipe into water?
Add a hot water coil to the exhaust stack, pump and piping to your tank. As far as turning pump on you could either have it turn on based on exhaust stack temp or water temp at the discharge side of the coil.
Yeah, I'd want to put some of that heat back in my wallet, too.
Water would probably be the most efficient way to extract heat from the exhaust stream, as BRL suggests. Cramming that much air through a truck radiator would probably need a more powerful fan to keep the required airflow going, though.
Just keep in mind that if that exhaust temp is 350F or more it could easily boil water to steam. You want a bulletproof way to make sure the pump is circulating water through your heat exchanger any time the exhaust temp is over maybe 180F (or something) for safety margin sake.
P.S. You might need to deal with some fume condensation from all the water in that large a gas flame. Mostly acidic water from the gas fire and whatever fumes your process might be giving off.
What's the cfm of the exhaust fan? What kind of particulates does the forge throw out? I'd be worried about that clogging something as fine as a car radiator or HVAC water coil. Maybe duct it into the bottom of a NG boiler, something with large flue passages and just treat the exhaust as a flame.
My forge runs about 2800 degrees inside. There are no fumes or smoke and the only dirt is dust in the shop air. I am sure I would have it clean a radiator or hvac coil at the end of the season. Whatever I end up using will need to be removed from the pipe at the end of the heating season. The ductwork runs overhead so any heat recovery will need to be up there too or I would just run the pipe through the water tank. Maybe a water jacket around the pipe or a tube coiled inside would work. I want something that will be efficient so the heat does not simply zip right on past.
Do you know anyone that could work with stainless? Maybe fab up a heat exchanger with a bunch of 1.5" tubes about 3' long (just like gasifiers use) with water surrounding them. Just make sure the area of all the tubes equals the area of your 12" existing and you shouldn't effect airflow. If I have time I'll draw up something to give you the idea. Brian
find a stump 11" or so diameter. get 3/4"? coppertubing & wrap around the stump however many times. remove 11" coil from stump & install on exhaust flue, it should fit tight on 12" flue. install 1 pressure releaSE VALVE AT EACH END OF COIL. PUMP FROM TANK INTO COIL & BACK.
I would go with a cast iron radiator!
I like the tube idea. I just removed a steel tube boiler from my house that would have been heavy @ 250lbs + water but nice easy flue passages to brush once a year, and about 80% efficient depending on the air flow. Just cut a larger hole into the firing chamber.
The forge burns propane, 250,000BTU. Brian, I am familiar with a heat exchanger that uses tubes like you refered to. I can build anything as I have a very complete metal working shop. To get the same area as a 12" pipe it would take 64, 1 1/2" tubes. I know that would pull a lot of heat out but it would be heavy and take a lot of work to set up. I may just go with a coil inside like BLIMP suggested. Thanks, Danny
I don't think you're going to get enough heat transfer from an exterior coil. I think your best chance for maximum heat transfer would be something like the heat exchanger of a pool heater or as you suggested a radiator would pull the heat through.
Rather than a truck radiator, how about a big unit heater (Modine, etc.) as an exchanger. It's designed for large air flows and, perhaps just as important, easy water flow through its larger tubing. You can find these as used industrial surplus sometimes. They also are designed to get all the air out of the water lines, too.
water has a higher heat capacity than air, much better 3400 times better for the same volume.
Conduction is the best heat transfer mechanism. Wrapping a copper coil around the hood or pipe would be the best way to scrub some heat energy out.
But watch the flue gas temperature above the coil or hx. You need to stay above dew point. Condensing in the flue stack will cause dripping and rapid deterioration of the pipe.
hr
You'd have to flatten one side of the pipe to get any meaningfull transfer of heat, then insulate it to keep room air convection from robbing you of your gained heat.. Even then you will only be capturing the energy that comes in contact with the pipe while missing a majority of the area in the pipe, which is over 3x the circumference. If you've got a 12" pipe then your circumference is less than 37" but your area is over 113". The copper could work, but for every inch of exhaust pipe you'd need over 3' of copper tubing, getting expensive in a hurry @ $3-5 per foot.
I like the Modine heater idea. Made to hang, already plumbed for water, and pretty cheap if you get lucky. Problem however is the units use a mechanical fan to transfer heat past the coils/fins, which would have to be removed in this situation. What kind of reasonable constriction could be asked of draft fan on the forge?
Who said anything about putting the coil on the outside of the pipe? QUOTE; "I may just go with a coil inside like BLIMP suggested." I do have some copper tubing for a coil so I may use that before buying a Modine radiator. I did look up Modine and I figure it would work as well in reverse as the way it is designed to. To answer the draft question, some heat does blast out of the forge and out from the hood. A little more heat getting past in the winter is ok. I can always open the door for more ventilation. As far as condensation goes I dont think it will be a problem. With all that airflow and 350*F I would say anything that drips will get evaporated fast. Even if it drips down the outside of the pipe I can stick a bucket under it. This is in a shop. Right now I am getting ready to dig a hole for a tank and pour a concrete floor. I'll keep you updated. Thanks, Danny
Keep CO (carbon monoxide) in mind if you pull byproducts of combustion from the exhaust hood. It's a silent killer. CO detectors are cheap insurance.
hr
