KevinACrider said:That's the top of the stove? Yikes! I thought it was a damper plate!
I'm with CF, if that's the stove top, get rid of that thing!
KevinACrider said:You need an insert boot. That should work.
Red5 said:Hogwildz said:Get a new insert.
why? what wrong with this one?
Wood Heat Stoves said:you need a boot, and an 8-6 reducer.
bad idea to vent that unit using 6" pipe--it should be 8"
but like they mentioned, the stove you have there is worth too little to install an expensive liner imo
BeGreen said:Splice on additional footage of rigid, 6" stainless liner to the top of the current flex liner so that you have enough. Be sure to add enough on top to make it past the chimney cap plate and accommodate a storm collar and cap. Then trim excess on the bottom as needed.
