I have a Masonary bit and hammer drill but I think I shouldn't use the Masonary bit to go through the steel...correct? Normal drill through the steel then switch to Masonary.....Masonry bits. Oh, and they work best in a hammer drill, might be ok in a regular drill since you are doing 1-2 holes
Found an unused sharp drill and got it! Thanks.....I was using some POS drill.....Get a new, sharp bit. It should go through that metal pretty easily. Titanium coated bits work better.
