I need a plate style HX. I did the home heat load on alternitive heatings site it said 90,000 btu wich one do i need
fabguy01 said:I need a plate style HX. I did the home heat load on alternitive heatings site it said 90,000 btu wich one do i need
1" both sides, havent made a decision on pump but was thinking a 3 speedheaterman said:fabguy01 said:I need a plate style HX. I did the home heat load on alternitive heatings site it said 90,000 btu wich one do i need
What size tube are you going in and out with on both sides and how much flow rate do you have to work with. Low flow rates and close approach temperatures (approach = incoming boiler water temp compared to supply out temp) often mean a HX that is significantly larger than what is usually guessed at by a lot of installers.
fabguy01 said:http://www.mcmaster.com/#35115k63/=40poj2 ????
http://www.grainger.com/Grainger/items/2NXR7 ????
