OK I've decided, since we have some elm this winter, that splitting by hand is useful, builds character, and works well on pine. But since my welder is feeling neglected, and the cure for chilly fall evenings is often found in the shop, that I need to build a splitter. So here's what I'm thinging/wondering:
1) How many HP for the motor? I'm assuming a minimum 4" cylinder with about 20" or more of throw. Would 12-15 HP from a lawn tractor do it, or do I need more like a 4-cyl or diesel industrial?
2) What size pump and reservoir works well?
3) What do I need for a frame? I'm looking at some I-beam, either 8" or 12", either one is available
4) What's the best for the point? I've seen some that are just 1/2" plate with an edge, others are a lot wider.
Ideas: Buy in town has an old Jacobsen hydraulic lawnmower. Probably about 12-15 HP, hydraulic drive to the wheels and the mowers (3 of them). I can get it for $150, motor runs and no hydraulic leaks. Would this be a good beginning? I can keep the mower on the frame, and use the existing forward/back controls for the hydraulics.
Mostly stationary, I'll add 16" wheels and tires and a hitch to pull it in the back woods as needed. Probably add a log lift, if the motor will do it?
Thoughts/suggestions welcome, thanks!
