Hello, new to wood burners and heating with wood in general. We recently purchased a used hotblast wood stove. It over all is in good condition and we were told it worked fine when removed. The issue we are having is regardless of how hot we get the furnace the supply air that the blower is pushing out is warm at best maybe 50 degrees max. This is causing the blower to kick on and off and only run a couple minutes at a time even with the thermodial at 100 degrees. The blower does not appear to be original and is very big. Could the blower be to large? A friend of ours has a very similar unit and he has no problem getting his 2,000 sqft house 80+ degrees however we can’t even warm up a single wide trailer. The stove is in an addition and I originally thought maybe since the room was so cold to begin with the blower was blowing cold air across the furnace cooling it down. Tonight I used a torpedo heater and got the room up to about 60-70 degrees with the same results. Anybody have any ideas on what I’m doing wrong?
Thanks in advance!
			Thanks in advance!
