The Wood Gun manual shows several options to use the installed DHW coil along with an electric water heater. One option is plumbing the coil in series with the electric tank. To do this does the electric heater always need to be on to avoid scalding hot water? Is it possible the electric water heater would be adversely affected by very high temp water coming form the boiler coil?
Next option shows the coil direct with a tempering valve and it appears 2 shut off valves to allow use of the electric or the coil independently. Finally it shows coil parallel with electric tank and a small circulator between the coil and the electric tank(the circulator can be eliminated if you can thermosyphon?).
I guess my dilemma is what are the pro's and con's to each set up? I plan to run the electric heater only in the summer and will rely on the boiler's coil for DHW the remainder of the year.
