As the discussion regarding the expense / benefit ratio of gassers versus OWB's rages on, I had a brain fart the other morning that went something like ...
If I want to heat a conventional ducted air system with hot water by adding a large (ish) hydronic coil into the ducting, why then can't I get hot water FROM the heated air via the same hydronic coil. So, for those that already have a good, efficient, primary air heat source (like a propane furnace) and could benefit from an alternate hot-water source, install an hydronic coil sized for the new load (such as side-arm heat exchanger) and get hot water any time the furnace is running to heat the house. I understand that you would be taking BTU's out of the air stream, but that could be accounted for by a variable-speed pump and supply air temperature sensor to ensure a minimum down-stream air temp.
Further, as I already have an(aging) oil furnace ducted to an RSF-100 wood furnace (modified by me for greater efficiency) that is then ducted to the house ducting, I could install the hydronic coil to use all (excess) heat that the big wood furnace is cranking out without have to damper it down or otherwise overheat the house. (frequently, as i don't like dampering combustion air and creosoting up the old chimney) I would use this heat to preheat domestic hot water (sidearm xchanger) Also, to increase actual BTU-HR capability, I could damper the suplly air immediately back to the return duct to create a short loop where the air goes through the oil furnace (and fan), through the wood furnace, through the hydronic coil and damper back to return air to oil furnace, etc. Damper would auto-open on call for heat from house and pump would NOT run if oil was heating the air (electric hot water tank).
Any thoughts as to the efficiency of this scenario and / or if it is started in the wrong list? Cheers!
