I just got done fixing the leaks on my Jacuzzi outdoor spa. This involved taking off all the skirting and removing the foam insulation. It turned out that a number of mice had carved nests into the foam. I cleaned those voids and sprayed in some expanding foam insulation. As I'm putting back the insulation, I'm noticing lots of areas where I could fit additional insulation. My first thought was Styrofoam panels, cut and wedged in. Then I got to thinking about fiberglass batting... it would be easy to push into the spaces between the the existing foam and the shell of the hot tub.
Anyone have experience with this? My main concern is moisture; as long as it doesn't leak again, it *should* stay dry. What happens if this stuff gets a little wet? A lot wet? Any other ideas or thoughts on how to insulate this space?
TIA,
Tres
TIA,
Tres
