I have ni expeience hot smoking.
Can I just throw some green cherry branches into my gas grill with a pork shoulder?
Keep in mind that the thickness is what you are fighting. Pork is done at 145F and perfectly safe for consumption but if you are going for the classic "pulled pork" thing you will want to finish off higher, about 200F plus or minus 5. The hard core pros usually shoot for 205F internal. Remember carry over temp. Internal temp will continue to rise for a bit even after you pull and wrap the roast.Plus I cut the shoulder in half so it is only 5 pounds
That's cool because I have a genesis too, so this is really easy to follow. Thanks.I smoked some bacon on my Weber Genesis the other day.
A big foil roasting pan full of water, that covers most of the area under the grates, helps to even out temps and keep from grilling the meat instead of smoking it. The pan I use leaves enough room at the end for a few chunks of whatever wood I want to use for smoke, set right on the flavorizer bars.
The trick is to experiment with the setup to reach your target temp, and maintain it. Once it's up to temp, I can hold 210-225 with the center burner on a medium-ish setting. You don't want the water to boil, or you'll have mushy, steamed meat, and evaporation keeps the water temp just under boiling when it's 225° at the grill. And I use a remote oven thermometer, with the probe right at the grilling surface, next to the meat.
Boiling the water on the turkey fryer and pouring it in the roasting pan saves a ton of time in getting the temp up and stabilized. Ambient temp and direct sunlight, especially if you have a black grill, can make a difference too.
I've only smoked bacon this way. It works pretty well, and requires minimal attention since I've done it a couple times. I don't see why 10+ hours for a shoulder would be any different.
OP - also check how you grill top sits on the bottom before you try to do it. Our Ducane BBQ (made by Weber) has an opening about 1.5" across the back where the top meets the bottom, supposedly for heat exhaust. When I tried doing low and slow in it, it ends up using way more fuel than needed because a good whack of the available heat is simply venting out. Make sure you don't have the same "feature". If there's a small gap, you're good to go.
Not necessarily. I do like the BGE and think it is a fantastic piece of cookware but it is really hard to beat a dedicated smoker.
For the record - on labor day I will be smoking up 9 full shoulders.
