liston said:I commute into town to earn my living and am gone for 10 hours at least. So the new EPA stove is burning cool all that time. There are coals when I get home and I just build it up again. The stove is soapstone and it takes a few hours to get into the "no creosote" temperature range. Is my lifestyle (being away from the farm all day) incompatible with heating with wood? I've lived with wood heat for 30 years, but only recently by myself. My husband used to take care of the stove during the day. Now he spends his winters in the tropics (jungle tour guide). Opinions please!
BeGreen said:Hard to say what the temp of the flue gas will be coming out of the top of the chimney. There are too many variables like chimney height, outdoor exposure, stove operating temp, outside temps, etc. I usually try to burn my first fire a little hot, with about 6-700F probe flue temp for about 15-20 minutes. We have an interior flue and only burn dry wood. The flue was cleaned last fall. There were a couple cups of dry flakey stuff collected, after about 8 cords of wood burnt over 3.5 seasons. But I have gone up on the roof and checked the top section every year, just to be sure. If you are new to your stove or burning wood that you are uncertain of its moisture content, there is no substitute for a proper cleaning done as frequently as needed. If the wood is damp, this could be a frequent as every few weeks.
FWIW, this is documented in some stove manuals. Ironically I just finished reading this one:
"To prevent creosote build-up in the pipes, the stove should be run between 800°F and
900°F for 30-45 minutes each burning day." (Assuming they mean with a probe thermometer).
PS: Just checked some more manuals. This is from the Regency 2400:
Ways to Prevent and Keep Unit Free of Creosote
1) Burn stove with the draft control wide open
for about 10-15 minutes every morning
during burning season.
2) Burn stove with draft control wide open
for about 10 - 15 minutes every time you
apply fresh wood. This allows the wood to
achieve the charcoal stage faster and burns
up any unburned gas vapours which might
otherwise be deposited within the system.
3) Only burn seasoned wood! Avoid burning
wet or green wood. Seasoned wood has
been dried at least one year.
4) A small hot fi re is preferable to a large
smouldering one that can deposit creosote
within the system.
5) Check the chimney at least twice a month
during the burning season for creosote
build-up.
6) Have chimney system and unit cleaned by
competent chimney sweeps twice a year
during the fi rst year of use and at least once
a year thereafter or when a signifi cant layer
of creosote has accumulated (3 mm/1/8" or
more) it should be removed to reduce the
risk of a chimney fire
Backwoods Savage said:BeGreen, this is just another example of someone copying some stuff they read somewhere else and then they pass it on as wisdom of wood burning. Sad to see it just passed on and on but we see it even in the old almanacs. Some folks just aren't aware of what is truly necessary vs. some over-ages baloney. However, some of what they printed is still wise even today so we won't bash them too hard.
