All,
I am looking at the install manual to the PP60 here and the parts I have and it lines up to a direct vent/horizontal flue pipe install. I am looking through some ideas and it appears a lot of pellet stoves have low horizontal rear flue vent ports so the configuration of the set up (parts, stove) I have here seems like it would line up to be a pretty common set up.
Looking at the manual of the PP60 they show the horizontal/direct vent option:
Looking in to direct vent/horizontal venting I came across the following thread discussing this and found the associated following picture:
www.hearth.com
As captioned in the picture - "Why never to direct vent a pellet stove".
Then I find this tip in my manual:
The picture above certainly does not look like to me it is that 18" dimension, but it looks like it would be around the 6" dimension.
So my question is two parts:
1. Would increasing the distance significantly reduce the soot blow-back issue?
2. If you combine the increased distance with a shield of some kind can the soot blow-back/soot accumulation on exterior surfaces be eliminated?
Has anyone done this with any success?
Install Complete - With Pictures
Breckwell Big-E purchased summer 08 and installed Nov 08. First install was in the basement but did not work. This seems to work much better upstairs although weather has been rather warm here in PA. Setting of 2 or 3 should do the trick. I guess I should think of putting some fuel stabilizer in...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
