Hopper
naughted
24
What do some of you do to keep the pellets from clinging to the side of the hopper and not feeding the auger. I have had the fire go out a couple of times due to this. The brand of pellets I was using was inconsistent in size and had a lot of fines in it. I have switched brands and the new pellets are larger and more consistent with a lot less fines. I have done a thorough cleaning of the stove and emptied and cleaned the hopper. Before I add pellets is there something I should coat the hopper with?
I started having problems and emptied the hopper, scrubbed it down with scotchbrite and a little paint thinner. let it dry for about three hours and sprayed the whole thing with Teflon lube. It hasn't eliminated the problem, but has greatly improved the movement. I have thought about lining the hopper with HDPE, but I want to run so temperature tests first. I think it's good to about 400*F, but I want some margin. I'd only do the upper half where the jams occur, not the lower parts where the heat really builds.
