So the noises i had thought were squeaking metal from auger or something is actually high pitch vacuum leaks from hopper lid seal. When I looked up PN:
1-00-375501
It shows it to be a roll vs single rectangle/oval seal like expected...actually now see seam behind latch which is certainly part of where it is leaking.
So I was thinking of buying a sheet of material to make new seal. Or I can buy OEM. Or make from some other roll similar high temp neoprene like material roll but making the turns required assume would not work well. Or add layer/fix seam...
Has anyone replaced this seal? I could not find thread or posts.
![Hopper lid seal replacement Harmon Accentra insert (original version) Hopper lid seal replacement Harmon Accentra insert (original version)](https://www.hearth.com/talk/data/attachments/301/301530-e32098d46a56b259359de139f0202fec.jpg)
1-00-375501
![Hopper lid seal replacement Harmon Accentra insert (original version) Hopper lid seal replacement Harmon Accentra insert (original version)](https://www.hearth.com/talk/data/attachments/301/301529-5c6c92d03dfd8719811224236e8ec426.jpg)
