Hi,
Newbee question, but I did search first.
I have 80 gal DHW with solar coil in the bottom, and a side arm hx heated by the boilers primary circulator. On the top exit I have the Honeywell Tempering.mixer. It does get preheated (or prewarmed) water from the boilers DHW coil as the feed to the cold side of the mixer.
The first question is do these mixers make noise when flowing? Somewhere I have noise as DHW is drawn. It seems to be a knocking type rattle, not the tinkling sound of air in the lines.
Second, should I just run the pre-warmed water to the tank, and feed the C side of the mixer with real cold water? Or run a second mixer with real cold? I saw someone mention that they had two. I'm want it to be safe for showers, of course, but I was wondering if the prewarmed water in the cold side of the mixer might be confusing the logic in the mixer, causing the gates to rattle, as they try to cool the outflow.
Thanks in advance.
Al
Thanks in advance.
Al
