Honey Bear gasket size help please
slugboy6000
11
Ontario, Canada
I'd like to replace the door gasket on a Fisher Honey Bear with glass doors.
The old gasket that I removed is somewhere between 1/4" - 3/8" round, but I suspect it's not original.
I tried 1/2" rope, it's too bulky for the door to close.
Cardboard strips placed in the channel iron on the stove body are also too thick for the door to close.
This makes me wonder if round gasket was specified at all for this stove, as some of it was missing.
Whatever it needs, has to compress down to 1/16"-1/8" from the looks of it.
I couldn't find any info on the forum, or in the manual (thanks coaly for posting). The manual does specify 1/4" flat gasket for the glass which I can't find locally unfortunately.
I attached some photos for reference.
Regards,
-Richard
  • Honey Bear gasket size help please
Yours uses flat gasket in the channel iron (door seal) attached to stove as shown below;
Later versions with no channel iron (door seal) use much thicker gasket on the doors;
Honey Bear gasket size help please Notice the flat stove front with no door seal. This was also the style of the Model IV glass doors.
Notice our U.S Honey Bears didn't have the ash fender trim and look frail compared to yours too.
Hi coaly, thanks for the response. I thought I needed the flat gasket after reading some of your older posts....but there is no play when I shut the doors without any gasket. The shape of the mating parts don't seem to indicate flat gasket either, as I wouldn't get the triple seal found in non-gasketed stoves (I drew a picture of what I'm seeing).
Yep, keep the cement thin and use the thinnest flat gasket you can get. (for glass) It only acts as a cushion when you close the door. It will crush. Solid cast iron doors didn't use any. My picture shows a "like new" Honey Bear that was only fired to cure paint. The new looking gasket is original. Here's a used one that has crushed from use.
Solid doors;
I cemented a 1/8" thick flat gasket to the channel iron on the honey bear. The gasket wasn't for glass specifically, but was the thinnest I could get locally. Maybe I used a little too much cement?.. time will tell.
It worked out pretty well, the doors require some force to close, but they do close.
Thanks coaly
