homeowner saw vs pro saw
hpcbmw
24
NorCal
EDIT: Ok, I guess I don't know what a "pro saw" is. If I could, I'd change the title to "homeowner saw vs. next step up saw".
Newish guy here. I got some great advice on this forum back in November, so I'm back with more questions. I bought a house on .8 acres with about a dozen 80' digger pines that will be cut down in the next few years. To save money, I'm paying a tree service to dismantle them and chip the brush, but leave the logs for me to cut into rounds and stack.
I bought a Poulan 4218 42cc 18" bar in November and got quite a bit of use out of it. However, it just quit on me and I've got a whole summer of trees to cut. I rebuilt the carb, but no luck. I then checked compression, which is only about 50 psi. I'm not sure if I ran a poor gas mixture, old gas (will that ruin the piston/cylinder?) or if I ran it too hard and overheated it. I plan to pull it apart and if it just needs cylinder or rings, replace them and get it running again, but that's a project I don't have time for right now.
I borrowed a friends Husky 445 for some of the bigger stuff, and realized that I rarely need something that big and heavy. I consider the Poulan a "trainer" chainsaw. I learned alot about cutting trees and bucking logs, plus about the ethanol in pump gas, engineered fuel, old gas, etc.
I looked at a bunch of used chainsaws and they are selling at 75% of new here in Northern California, plus most of them have been stored with pump gas for a year and run rough - meaning they probably need at least a carb rebuild, so it's not worth it to me.
Ok, now for my question - I see Stihl MS170 for $159 and Husky 240 for $179. Both seem like a good deal for a small, user friendly saw. The pro models are $100 more. I can swing under $200 from tax return money, but $300- $400 is a real stretch. What will I get with a pro model that I won't get with a home owner model? A 16" or 18" chain seems to work well for bucking logs, plus the tree trimming and pruning I've been doing myself (sometimes climbing 40' into trees to trim branches up to 10").
Thanks for any advice!
What Pro saws are you looking at for under $400? If you think your friends Husqvarna 445 was too large for you, then there is little point in looking at any Pro level saws. I think either of the smaller saws you listed will fulfill your needs.
Do you have a good dolmar dealer nearby ? If so check out a Dolmar PS 421. I have spent time cutting with one and it's a very nice saw.
42 cc saw with pro/commercial grade construction at home owner prices. Made in Germany. Very high quality for mid $300 price range. And twice the saw of any of the ones you listed in the thread in terms of quality and construction. Slightly bigger than a stihl 170 or husky 240 but not much. Light and easy to handle saw with a broad range of uses
The difference between a pro saw and homeowner saw is based on the design of the construction. A pro saw of any brand will have magnesium cases split vertically which hold the lower end assembly, clutch, etc. The cylinder ( top end ) bolts directly onto those magnesium cases. A saw built around an engine.
A homeowner saw uses plastic cases which hold the lower end crank assembly which drops into the plastic cases. Cheaper to manufacture so lower cost to the consumer. Will not hold up as well over long term use. Still fine saws for many people though. Just depends on what your doing with the saw, as with any tool.
Of the 2 small saws you asked about ( stihl ms 170 and husky 240) I would suggest the Stihl. It has a far better clutch than the husky. And I'm a husky fan their pro saws are exceptional tools, but the 240 is in my opinion not as good of a deal and not as good of a saw as the ms170.
Echo cs 490, $350.00, 50cc, get the 16" or 18" it comes with a 20". Light and powerful.
  • homeowner saw vs pro saw
Reactions: Grateful11
Just my advice and what works for me. I had only bought and used polans as "training saws"for years. The echo is lighter and cuts better and faster causing less fatigue. By wight it is lighter than the husky as well. By a 16" blade and grow into the saw instead of another when the need arises. In the end it's just my thoughts and advice.
Sent from my SM-G900V using Tapatalk
If you're interested in an Echo at all do yourself a favor and see if any of these dealers are near you at the link below. There may be a 20% day coming to a dealer in your area. That's what we did last Fall when picking up 2 new Echo's. No one here on the farm has ever been a big Echo fan but these newer saws are nice. The CS-400 might suit you well.
http://www.echo-usa.com/Products/Chain-Saws/CS-400
http://www.echo-usa.com/Promotions/One-Day-Sale
If you're only going to have one saw I'd look to something more than an MS170. Husky 240 is very lowend. If sticking with Husky look at a 435. With Stihl look at an MS250 or MS251
Seconded. All of it.
Great info, thanks guys! There are no Dolmar dealers near me. There is an Echo dealer nearby with a sale date next week. For 20% off, the Echo CS 490 is right about $300 with tax. It looks like the echo has comparable weight to the entry level Stihl and Husky. I'll probably look at the Echo at the sale next week, and start with a 16 or 18" bar.
Thanks for clarifying the pro vs. homeowner (saw built around engine vs. plastic case saw).
I have zero experience with echo but I've read lots of positive stuff about them. People who own them praise them for being good quality and a great value. As is the case with Dolmar, and echo, you get a lot of saw for the money.
The cs490 appears to be a 50cc saw. Sure a little bigger than what you initially were thinking of getting. However it's still a lightweight saw and in my opinion fits in the easy to use category.
All saws are dangerous if used in an unsafe manner regardless if it's a stihl 170 or a bigger saw. Getting comfortable with a 50cc saw generally doesn't take that long, there is a short learning curve because they are fairly easy to handle, but this is why so many people use a 50cc saw and for firewood and storm clean up around the yard they usually are a perfect size. After you are comfortable with it the beauty of it is with 50cc you can actually do a lot of cutting ! Big and small trees !
Reactions: Fred Wright
I have three different saws all Stihl they are used for different purposes
The MS 250 is my oldest saw and my go to fire wood unit good power light
enough that you can use it all day . The MS 291 is for the big stuff in bucking
fire wood a little more weight and power . The MS 461 is the felling saw for the
big stuff and for bucking the really big stuff . Not a saw I could use all day
getting to old to sling that weight for long periods. Long bar ,heavy and loads of
power . If I could only have one saw I would choose the MS250
If the OP stated they thought a Husqvarna 445 was too much saw for them, I see no point in recommending an even bigger saw.
I'm a bit confused on that point:
Poulan 4218 - 42cc, 18in, ~11 pounds
Husqvarna 445 - 45cc, 16-20in, ~11 pounds
I wonder if the Husqvarna simply cut enough better than he was used to that it seemed like a bigger saw.
It seems to me 40-50cc is probably the range the OP should be looking at, especially considering he's talking about bucking a decent number of relatively large pines (and I presume will continue to scrounge firewood in future years once he's done with the wood from his property). I'm sure the MS170 and similar can suffice and would definitely be more convenient for the trimming work, but it doesn't seem ideal for his main intended use.
Reactions: Lone_Gun
The Poulan 4218 was probably a strato set too lean at the factory and scored P, R & C. It's a crime with these EPA games. Last I looked, a top end kit was $75 for these saws. Not worth it, IMO. IF this class saw did all you needed, you could look at refurbed Poulans - eg. VMInnovations has them for ~$80-$90. But do tune saw richer and mod the muffler for more power.
Reactions: CTYank
IMO do look at VMInnovations and don't waste your $ on stihl. Why? Ferinstance their wee-ones have stamped mild-steel rods. POS. I got a PP4218 from VMInnovations a few years back as a backup/truck saw, richened up the top end a bit, tossed the "Torch" plug for one a step colder than spec, replaced the soft-steel chain. It still punches above its weight, and is smooth & quiet.
With a whole summer of trees to cut, depending on the size, I'd look into a 60cc saw. Something like a nice used Stihl ms362, or a Dolmar, or 562XP Husky. The power, torque, reliability of the pro saws makes them worth the money if you're using them often enough. I like big saws though, and would rather have bigger and cut and buck more quickly, than a light saw that I have to hold for twice as long to do the same amount of work.
Reactions: Sean McGillicuddy
But with a 60cc pro saw, it wouldn't be a whole summer's worth. It might not even be a whole weekend's worth, and then how do you justify the purchase? ;)
More power plus less weight is more fun.
I've learned (from my dad) to save extra and buy commercial or pro versions whenever you can when it comes to tools and equipment. Overall he's right. Pro tools hold value better, are serviceable years later vs throwaway or obsolete parts, generally make a task a lot more pleasurable and you really can feel quality when you pick up and use a pro tool.
I'm too poor to buy cheap tools
Right on. Unless the saw is going to sit on the shelf and only get used once in a blue moon, I'd go pro. Your mention of being serviceable is another big advantage. The pro saws are meant to be rebuilt again, and again. And they're cheap to rebuild.
Quick story tonight: I brought my Stihl 361 to the neighbors and ran it side by side with him and his similar size stihl homeowner saw while bucking up a bunch of cherry we cut down. He then asked to use my saw and was blown away by the power difference. Told me he was shocked how much faster I was bucking, and he had a brand new Stihl yellow chain on.
Saws are within a few cc of each other, and weigh/look the same. Pro saws are fun!
For what it's worth a homeowner plastic clamshell saw can also be rebuilt if need be.
All of my saws are pro grade. But still I'm not personally going to say someone shouldn't by a homeowner model. If someone only cuts up 1 to 2 cords of firewood a year that means they are only running the saw a few hours a year. In that scenario if I were selling saws ( I don't ) and a customer came in looking at a $350 homeowner saw vs a $550 pro saw telling me they were running it a few hours a year, I might have a hard time sleeping at night pushing the pro saw on them.
Now if someone appreciates the quality of a better built tool then naturally buy the pro saw.
I run my saws sometimes 3 or 4 days a week during certain parts of the year. Easily a gallon of premix a day during some weeks. For me it's a no brainer a pro saw is the better fit. But for the firewood cutter burning a cord a year there is also a good argument to spend less, keep more money in your pocket.
Ditto on rebuilding a homeowner clamshell - you can do it - it's just 4 more bolts. Problem is price. Topend costs $60-$70 on a saw selling for $60-$70. The aftermarket supply system doesn't make kits and maybe won't. These saws have become considered throwaways. I've got 5 strato Poulans in boxes with scored P & C.
Best advice I can give: you need more than one saw. One viable combo is a 60 cc, a 40 cc and a polesaw. The big one for felling & bucking, the smaller one for limbing, the polesaw for lengthening your arms cutting smaller stuff. Seems you'll have lots of work for all of them.
One way to beat yourself up is to use only a large heavy saw for all the cutting. Risky behavior- fatigue clouds judgement.
Reactions: kevin j
