I can't find anybody selling replacement pipe for my OAK to save my life. I've either went to or called every hardware store, farm store, stove store, and auto parts store that I know of within driving distance and nobody has anything close to the 2" flexible aluminum pipe that I need. I've been on ebay, amazon, and every hinkey fly by night web store that turns up in the first couple pages of several search engine's results. And still no luck. So last night, after waiting around all afternoon for the last local stove place to blow me off instead of calling back like they said they would I decided **** it, I'm going to try to make my own with foil tape and bailing wire.
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143931-06be221fecb35c5a784f226feacbcce4.jpg)
It worked out really well. I figured I can't be the only guy who ran into this problem so I might as well throw together a little how I did it for anybody else having a hard time finding aluminum flex pipe.
I found a piece of 1 1/2" schedule 40 PVC that had about the right O.D. (1 7/8") to use as a form
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143932-e85f6be5081aa1d58341c78f60d89cfa.jpg)
First I hung the pvc pipe off the edge of the table and wrapped a layer of foil tape around it with the sticky side up. When you get yourself, the tape, and the pvc situated just right it's pretty easy going. Just twist the pipe with one hand and guide the tape on with the other, pausing to peel off the backing strip off the tape as necessary. Just let the tape roll on the floor. Try to overlap about half the width of the tape. Continue on until you reach you desired length of
Now get a couple strips of foil tape read to go
And let your bailing wire unravel into a rats nest on the floor.
Get a few wraps of bailing wire around the end and use one piece of foil tape to hold it in place and keep it from unraveling as you go.
Now wrap it just like the tape. Spin the pipe with one hand guide the wire with the other. I tried to maintain about a half inch space between the wire and that seems to have worked pretty good, doesn't have to be perfect just close enough. I think a smaller space would make your flex pipe more rigid and a wider space less rigid, but I haven't tested the theory. When you get to the end use the other piece of foil tape to hold the wire in place
Snip the end of the bailing wire.
Now flop your roll of foil tape around and wrap it with a second layer of tape sticky side down. Just like before twist the pipe with one hand and guide the tape on with the other, pausing to peel off the backing strip off the tape as necessary.
rollin' rollin' rollin' do-do do-do do-do .... It is kind of slow goin' especially when you have a long piece to make.
Stay tuned, I hit the picture limit for one message.
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143933-be2f5b13ca54a8e3841dd4144887fa48.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143936-9053075a51d707728af958837d42b774.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143934-dea9029ffde065da50f0d622c29ce90c.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143937-71b63662aa4f70c9352ecffee7da389f.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143938-d5c40f1d826a94fb502fda2cfba7b008.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143939-aae8d1786e26ab351bdd67c81fd0b376.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143940-c93e5d763aba690fa8b490e100bbce22.jpg)
![Homemade Flexible aluminum OAK pipe/tube/duct Homemade Flexible aluminum OAK pipe/tube/duct](https://www.hearth.com/talk/data/attachments/143/143941-7306f77718d03a7d5b33a17665752bac.jpg)
