New to the forum, but have been visiting for some time reading up on gasification boilers.. Thank you for all your post.
Wanted to share my gasification water heater that I built and is running on its second season now. I don't like calling it a boiler because I am not making steam. Anyway I did some simple calculations in my head for the size of the firebox, the secondary chamber and the heat exchanger on the backend. It is a down draft gasser, I have a preheater for the primary air and the secondary air has a second air heater. I have a 2" valve that I can control the secondary air for future o2 controller I would like to install. The water to flue gas heat exchanger is a retired 200 gallon propane tank that I gutted and installed 13 tubes in that are 2" in diameter and 5 feet long. I use some 1/4 in chain for turbulators and welding a some pipe on the end so I could chuck a drill to the end and use the chain as a pipe cleaner also. The heat exchanger is a pressurized one to keep the o2 out of the water. I have two 15 psi relief valve and one temp and pressure relief valves so the unit don't become a bomb in an event of over firing. I also have a 195 degree high water temp cutout to completely shut power down. UPS power backup for the water circulators to keep water moving in an event of power interruption.
I do achieve around 1500 to 1800 secondary flame, the fire box will hold roughly 7 to 10 cubic feet of wood. I get a continued 12 hour plus burn time. I load it at 5 am in the morning and then 6pm at night typically. I never let the water get below 150F and no hotter than 175F. I heat 2600 square foot 1910 fairly good insulated 1 and 1/2 story house using heat coils in the furnace. Also heat a 1200 square foot shop with radiant floor heat, will also be heating 3000 more square feet at 50F when I get my shop floor poured. The wood gasser sits in a 20 by 23 poorly insulated old garage that is about 65F from heat loss from the wood gasser. My flue gas temps range from 225F to 300F.
I will post some pics below, I could write about this thing all day. I learned a lot from the build and had to tweet air flows for about a month before I got it to work properly. Now I just load and go.
