herman said:well this is my second same saw from hd. the first one i used for less than 30 days cut & ran good then it started to not come up to full rpm, seemed to back fire thru the carb. & cut out. so i took it back for a xchange, no problem they gave me a new one got it home gased it up put chain oil in fired it up let it idle for 10 min. seemed to run fine wiped it down & put it in the box, yes now i`m ready to go cut wood, well.
nxt day opened case oil all over bottom of case, ok just oil left from running it wiped it down put away nxt day got ready to go cut wood & guess what...... bid puddle of oil in the case, again.
i got a oil leaker, back to hd tody to xchange it again or should i.
anyone have this kind of problem. ??
herman said:i did get the helmet when i got thev saw. chain saw boots, chaps & gloves where do you get these. ?
herman said:used the homelite yesterday first time for this one,had a terrible time getting it started & warmed up, bogged down when i gassed it. after cutting shut it off to load wood tried to start again man i lked to pulled my arm off very hard to start pushed to bulb no gas coming into it sounded like it was sucking air, yes there is gas in the tank.
this went on all day long, this saw is a P.O.S. & a P.I.T.A. !!
spent more time trying to start it & keep it running than i did cutting wood..
thanks for the info.goose & everybody, if i can`t get this saw to run, i`ll, i`ll .
herman
