laynes69 said:
Yeah, thats what im thinking of.
If you go here:
http://hearthstonestoves.com/wood_stoves/heritage/
then under "downloads", click on the Heritage "manual" and go to pg 6, you'll see their warning about breaking it....... As an engineer, it's my personal opinion that this stinks....the ceramic plate is a good idea but it's so unprotected that they have to issue a warning about possibly breaking it while insereting a log and thereby ruining your stoves ability to meet EPA specs
Here's what they say from the manual:
quote,
PLEASE EXERCISE CARE WHEN
LOADING WOOD OR CLEANING
YOUR STOVE, NOT TO DAMAGE THE
Thermo-Ceramic BAFFLE
Located directly above the burner tubes in the
firebox, this white sheet of material will break if
wood or cleaning brushes impact it. Be careful
when loading and cleaning your stove to not break
this material. If this piece has been fractured or a
hole is punctured, it will cause the stove to function
improperly. You must replace the board through a
qualified HearthStone dealer.
unquote
Now...a prospective consumer has to be asking him/herself two questions:
1) the first time you throw a piece of wood into the stove the wrong way and break this ceramic plate, how much is it going to cost you to fix it and/or can you even fix it yourself or will you have to have a tech come to your house or, worse yet, have to send it back to the factory?????
2) can you imagine if, in an automobile, they told you that if the passenger climbs in incorrectly that you'd ruin the emission system .......or that if you jammed the gas nozzle too hard into the fuel port that you'd also ruin the emission system????
How long do you think people would tolerate that......? Cat converters are protected by a steel plate.......this should also be protected.....
