home backup with Nissan Leaf battery modules
RustyShackleford
1,757
NC
I've been using our Nissan Leaf as a home backup-power solution for awhile now. Got that huge battery sitting around, why not use it ? Per this thread (to which I contributed heavily) ... https://mynissanleaf.com/threads/us...out-my-leaf-to-home.13097/page-11#post-568213
The Leaf's DC->DC converter (from the ~400v traction battery to the 12v one) can't handle much more than 100 amps of 12vdc power, so I used a 1000 watt 12vdc->120vac inverter. (There's not enough juice there to be able to handle any of the 240vac loads, and inverters with 240vac output are $1000+ anyhow - except maybe some very questionable-looking exceptions).
But I do expect to be able to handle the fridge, the internet modem and router, and a smattering of lights (mostly LEDs of course) and some outlets for the TV and such. But there's only one problem: Sometimes the inverter shuts off from overload, and the fridge is the culprit (turned off everything else); it's not the compressor startup surge, so it must be the auto-defrost. I can't figure out how to temporarily disable the auto-defrost.
So more 120vac power would solve this problem (and maybe another problem, see below).
I note you can get a LOT of storage for your dollar from old EV batteries, such as: https://www.greentecauto.com/hybrid...issan-leaf-nmo-7-6v-64ah-500wh-battery-module . We're talking well under $100 per kilowatt-hour. They'll sell you a packaged 48v unit (2+ kwh) with BMS for $500 or so. Seems appealing. Couple that with a bigger inverter (few thousand watts) and the fridge is no problem. Maybe I could even use a step-up transformer to power the only 240vac load I really miss, which is the submersible well pump. (Next time it fails, I'll replace with a soft-start unit, which should help a lot, but absent a lightning strike, that day is probably far off).
A couple kilowatt-hours should handle most outages, but I can always top it off with a charger powered by the current Lead setup (yeah, I know, high-voltage DC -> 12vdc - >120vac -> 48+vdc -> 120vac is not exactly efficient, but I can't think of a better way, unless there's a charger that incorporates a DC->DC converter so it can charge a 48v battery from the Leaf's 12v).
So I'm curious of folks' thoughts.
One thing concerns me though, and that is the fire hazard. I think lithium-iron-phosphate batteries are relatively safe, but that ain't batteries from an old Leaf. So how much should I worry about having a bunch of these in my basement or mechanical room ? How to mitigate ? Put 'em outside somehow, but obviously the cable to the inverter needs to be heavy, although that situation is a lot easier if the system operates at 48vdc.
If I had a decent place to store them safely away from the house maybe. It’s just not a project I’d want given the risk. I have not checked the price on LFP rack batteries lately. They would be my diy solution. But I did get solar and a power wall 3 on September. It’s just nice having it all automatic. The whole house. Is pricey but with solar Duke paid $9k up front and pays $52 a month. It’s about a 9-11 year payback at current electric prices. A transformer went down two weeks ago. It was almost a 5 hour outage nothing I would ever unplug a fridge and run a cord to the backup for. But it was really nice to have hot coffee lights internet with nothing else to do.
I’m not sure how well we would get along during a long term outage. Worst case scenario is 3-4 kWh left in the battery and it’s cloudy for a few days in a row. Coffee made on the camp stove. No internet only run a single fridge. It’s probably two days of essential only power. Edit…. Cloudiest day so far this fall i still produced 5kw. So that two day number could be a more.
Want to updgrade to a ford lightning? I haven’t look at the used market for them. Probably should.
If I’m just running fridges I think there are easier ways than a recycled diy battery bank. A 2000w Honda generator and 5 gallons of gas probably does a lot more for similar costs.
Internet isn't a power hungry thing? Fridge and Internet would be what I run in an outage (okay, from a genny, not a fancy battery as you and the OP).
Rusty, just Build a little shed for the batteries. Just don't put them in your woodshed - you'd be out of power AND heat if they burst into flame ...
My router and modem are running 60W . Add to that the DVR. A couple other network things it’s easier just to unplug the power strip.
Edit just looked up what my newest fridge uses. 1.6 kWh /day. I need to find my kill a watt and measure the router and modem can’t be 60 can it. It keep the top of the closet very warm
Reactions: stoveliker
I think mine is 10 W
Yeah, I always come back to the generator. Even a not very powerful one could handle the well pump, if none of the other 240vac loads.
Put it in a lean-to next to where the generator inlet is, move the propane tank there (the only propane load remaining is the cooktop, and it'd be a lot closer), and rig a quick-disconnect fitting to get propane to the generator. No worries about gas going stale, and even a 100gal propane tank has a lot more energy than however much gasoline you're going to want to have lying around.
I like the idea and thought of building one with Volt modules but never got around to tinkering with it. We already have a 2 kw propane backup generator. Now, our battery has wheels and the EV6's V2L adapter will provide 1500w power for a long time so we're covered with backup to the backup.
Reactions: EbS-P
Someone is going to come up with a residential HV DC vehicle to load soon that is really slick. Think direct dc charge on solar. The. The home battery needs to be tiny and you car battery can easily deliver 20kw to the inverter. Tesla should have this out already.
Reactions: begreen
Yes, it makes sense. With better weather forecasting one can often know a day or two in advance of a pending serious storm. Several EV6 owners reported charging up to 100% before Helene. After the storm, they could run their refrigeration and some lights and help out the neighbors for over a week on the car's battery.
Before I bought some LFPs, I was looking at using some Volt batteries that I have for backup. I thought I might house them inside a metal paint cabinet and use CO2 flooding to mitigate fire hazards. However, it seems that most lithium-based batteries generate their own oxygen, so this seemed mostly pointless. That's why ended up going with LFPs.
Reactions: EbS-P
