Well the AHS E-100 is in the basement in its place. Duct work hooked up. Have started to install the Joist Trak and hanger clips for the pex tubing. About half the house done. According to Uponor tech sheets they call for the pex feed/return holes (2 ea) to be 1-1/2" dia, spaced 4"-6" apart and 4" below the floor. I've seen pictures on the web that some folks used only one hole for both feed and return. Also seen holes that look to be a lot smaller. So my question is; should I follow Uponors spec, or how do you successful installers run pex?
Yes I know, without pictures it never happened. Will post some when I get further along.
Thanks,
Jim
Thanks,
Jim
