After experiencing firsthand the deterioration of a rubber type door gasket on my Wood Gun after only 1 heating season I am on a quest to find a better and longer lasting gasket. I think the new one I just installed and the other 2 doors should be OK for this heating season but I will probably replace all door seals next summer. The main characteristics I looked for were high temp resistence along with being able to withstand exposure to flame and below is what I have come up with:
http://www.firesleeveandtape.com/very-high-temperature-vermiculite-coated-fiberglass-rope.html
This one is rated to 500 F continued exposure...is that high enough?
http://www.adlinsulflex.com/high-temp-rope/
any thoughts? AHS sent me what appears to be standard fiberglass rope when I had ordered their "kit"...so they then sent me the so call kit which is basically a rubber type gasket and some high temp sealant which is exaclty what was on the doors to begin with. Shielding the gasket somehow from the flame/heat is probably the better solution to contimue to use the orginal gaskets but these gaskets may just do the job?
